PBR 300X2/Titan 6.5's
Is the PBR 300X2 a good pairing with the Titan 6.5’s used alone in the fairing. It was my understanding the Titans are 4 ohm speakers (could be wrong). It seems like they could use a bit more power. Wouldn’t the BT 2180/Titan II or the PBR/Kappa 6211i’s be a better pairing?
Thanks,
Rick
Thanks,
Rick
Hey guys,
Egldr, BT gear has a history of being under rated in the power numbers. So you could be very well be right that the Titan II could probably take a little bit more power, especially with the wattage the PBR is putting out at 4 ohms. The PBR does a good job of pushing the Kappas as they are 2 ohm speakers. If you're going to change one component or the other it is really up to you. If you like the fullness of the sound on the Titan speakers I'd say upgrade the amp. They should come alive even more with some more power.
Blowby, the PBR could push the 7.1's but not efficiently. There'd be no headroom left on the amp and you'd be working the **** out of the amp at all times. If you were going to upgrade to the 7.1's and only need a 2 channel amp I'd say get either the BT2180 or the Cerwin Vega B2 amp to drive them.
Hope that helps.
Hope that helps.
For me, this was more out of curiosity than anything. I've spent a good deal of time researching a system for myself over this past week and it got me wondering about my friends system (PBR 300X2/Titan II 6.5). I was thinking as good as these components are on their own maybe there was more to be had by swapping one or the other for a few bucks.
Thanks,
Rick
Thanks,
Rick
Thanks,
Rick
Thanks,
Rick
Thanks,
Rick
Doesn't the class A/D amp create heat issues in the fairing? The CV wouldn't cut it because he does listen to FM. I was thinking the 62.11i's would be a better match for the RF PBR300X2 and a cheap swap. Any appreciable sound quality loss with the Infinity's vs. the Titans?
Thanks,
Rick
Thanks,
Rick
Helping out my buddy here, as he is under attack LMAO...
I run BT71s now - LONG STORY, thanks to my buddies here Nutz, Gann, Haze and Dirt! - with the RZ4-2000D.
This amp goes far enough at this point in time for me pushing the BTs.
I got 90+Watts on the bench out of it during my testing, so on spec more or less (100W at 4ohm).
this amp costs 110 or so, you will have 2 open channels (I would not bridge it, but then again someone needs to try it LOL).
If bridging, you need to close off with 4 ohm speakers and theoretically you would be looking at ~250W RMS...
Hell - I am getting another RZ4 in for my little brother and once ready to install and dial in I will do a quick test test on the bridging to see the output on the scope.....
There is some truth to what you are saying Rick. The PBR300X2 performs better with 2 ohm speakers than 4 ohm. A better match for the X2 would be the Infinity 62.11i speakers. That said. The Titan II speakers need more power than the X2 can provide at 4 ohms to reach their full potential. Those speakers would be better matched with the Rockford Fosgate T400X2ad. Problem is the AD is not cheap and will cost more than a few bucks to swap out. A cheaper Alternative would be the Cerwin Vega B2 for the Titan II speakers.
