Harley Bluetooth Adapter: Harley-HC2
Does this work with the factory CB radio (pre 2014) using the PTT feature?
Someone has to have tried this.
http://www.spoiledbiker.com/product3326.html
Thanks
Thanks
My proposed setup would be a Sena SMH10 BT in helmet and the Harley-HC2 on the bike. My understanding is the HC2 works fine with BT. But I'm told in order to you the pre-2014 CB radios you have to use the PTT in order to talk. Which to me is not an issue. Just wanted to see if anyone has tried this yet with our CBs.
So, I'm dumb apparently. In the wiring schematic you posted in the other thread, you have a capacitor inline on the mic wire, and 470 ohm resistors upstream to a 10k resistor... what is any of that doing? I mean, I know what resistors and capacitors do, I just don't know what they're doing functionally in this application.
I've got a Sena SR10 and harness I made as well as a harness for the Sena SMH10 for an ultra classic like the Sierra Electronics one only my SMH10 harness actually mounts under the seat which makes install a lot less hassle. I made them and both work with my Harley but I'm getting rid of both to tinker with another device. if anyone's interested then PM me. Not looking to make much of anything. Just recoup costs of materials and move on to the next project.
