2014 rear speaker upgrade
Old 01-11-2015, 01:29 PM
roadkingdoc's Avatar
roadkingdoc
roadkingdoc is offline
Default 2014 rear speaker upgrade
what are my choices to up grade my rear speakers . the kappas will not fit. have biketronics up front and they are great. thanks
Old 01-11-2015, 01:32 PM
Rockrivr1's Avatar
Rockrivr1
Rockrivr1 is offline
Did you try installing the kappas? I was told the 62.11i will fit the rear pods, but that you'd need to do a little wiring to make them work.
Old 01-11-2015, 02:14 PM
zproud's Avatar
zproud
zproud is offline
The 2014 and up speaker pods are different, and the kappas would not fit in mine, e bay has a spacer from v twin audio that will allow the kappas to fit but the spacer is 89.99, I will be changing my speakers and would like a reasonable priced drop in speaker as well, mine will be amped by a pbr 300x2( don't want to hi jack)
Old 01-11-2015, 02:42 PM
Gannicus's Avatar
Gannicus
Gannicus is offline
Kicker KSC67 Very nice in the rear pods.
http://www.crutchfield.com/p_20641KS...1255385&awdv=c
Old 01-11-2015, 04:08 PM
Rockrivr1's Avatar
Rockrivr1
Are they plug and play or do you need to rewire to run them with an amp?
Old 01-11-2015, 05:03 PM
JMJOHN's Avatar
JMJOHN
JMJOHN is offline
Platinum Sponsor
J&Ms also work well, especially if you add an amp ,,, featured here http://www.jmcorp.com/ProductDetail....URK-6652TW-RXX ,,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old 01-11-2015, 05:13 PM
Gannicus's Avatar
Gannicus
Gannicus is offline
Basically run the existing rear speaker wires to the speaker side of the amp. . . Piece of cake!
Old 01-11-2015, 06:11 PM
zproud's Avatar
zproud
zproud is offline
Gannicus what about a 2ohm speaker for the 14 pods
Old 01-11-2015, 11:36 PM
Gannicus's Avatar
Gannicus
Gannicus is offline
The only rear 2 ohm speaker worth installing in the rear pods are the Infinity's and I'm told they won't fit in a 14 without an adapter. Now JM John claims to have a nice 2 ohm speaker for the 14's ($390 Bucks) but I have not heard them. I don't t like to recommend anything I have not installed and listened to myself. The only "other" 2 ohm speaker are the Booms.
Old 01-12-2015, 02:37 PM
JMJOHN's Avatar
JMJOHN
JMJOHN is offline
Platinum Sponsor
J&Ms ROKKER XX 2-ohm speaker kit is pretty cool for the rear trunk pod position on the 2014-2015 Ultras ,,, all plug-n-play, and includes spacers and custom grills http://www.jmcorp.com/ProductDetail....URK-6652TW-RXX ,,,,,,,
not sure what else I can do to it to make it perfect for this application, other than possibly a religious blessing from some of the folks here on HD-Forums ,,,,,,,
Quick Reply: 2014 rear speaker upgrade
