Soundstream PN4.520D Wiring Question
Just installed a Soundstream PN4.520D with Infinity Kappas all the way around on my 2011 Limited. HUGE thanks to everyone who has provided information on this forum - especially Ultranutz and Gannicus.
I'm a little confused about the wiring, though. I've attached a picture from the manual. On the high level inputs on the amp itself, it shows the wiring as +-G-+. On the wiring that plugs into the amp, it shows -+G-+. Which is correct??
Thank you!
Thank you!
Thank you!
Thank you!
I did not lose radio reception. My SiriusXM reception is also fine, and that antenna is mounted directly on top of the amp. Don't know about the CB. Haven't tried it.
I was pretty happy to retain my radio. I don't know why I didn't lose reception. The amp is mounted directly on top of of the radio.
I can't tell you if this makes a difference, but when I ran the power and ground back to the battery in the wiring tray under the gas tank, I was careful to keep those wires away from the FM/AM antenna wire. I also didn't run the power and ground through the wiring harness sleeve coming out of the fairing. I ran them out of the fairing by themselves on the right side.
I'll see if I can get some pictures tomorrow, and post them here.
stripe one is + - in this case you A:WAYS want to use the label on the Amp as the right one
I just installed this amp myself. I did notice I lost one of my preset stations on my radio. I was able to keep the main three stations I listed to around town which is what I really wanted. Kept 99.1, 98.5, and 100.7. Lost 97.5.
Who knows but I'm really happy about spending 100 bucks instead of 300 to power 4 speakers.
