2nd AMP Location
Old 12-12-2014 | 03:00 PM
Kokes58's Avatar
Kokes58
Default 2nd AMP Location
I'm going to add a 2nd Cerwin Vega AMP to my set up. I have an 09 Ultra. I currently have a Cerwin Vega B4 installed under the front fairing. Right now I have Kappa 62.11i's in the upper fairing and Infinity 612m's in the lower fairing running of B4 AMP. I have a Cerwin Vega B2 which I want to install for the Kappa 693.11i's I have installed in the saddlebag lids. I'm concerned if I mounted the B2 AMP under the fairing I will lose what little FM signal I do get. Can I mount the B2 AMP in one of the saddlebags or would heat be an issue when the saddlebag is full of stuff? My wife and I do a number of long weekend trips so there are times the bike is fully loaded. Also, am I better on running both front speakers (upper and lower) off the B4 or should I change around what speakers are running off which AMP? I assume it doesn't make a difference but want to get the smart people's input.
Thanks
Jerry
Old 12-12-2014 | 03:23 PM
Gannicus's Avatar
Gannicus
Thanks
Jerry
If the B2 is going to affect the radio signal it won't matter where you mount it. In my experience the amp either affects the signal or it doesn't. Since you carry a lot of stuff with the wife I would just mount it in the fairing using the hog tunes bracket. Running the upper and lower speakers with the B4 is good. That B2 is going to make those 6 x 9 infinities jump out of the saddlebags! lol Great set up!
Old 12-12-2014 | 04:57 PM
SBates08's Avatar
SBates08
Jerry I've gotta know...what did you use for grills on your 62.11s in the lowers?
2010 Limited with some stuff!!
Old 12-12-2014 | 05:22 PM
Kokes58's Avatar
Kokes58
I put Infinity 612m's in the lower fairing. I wanted to go with a marine grade speaker as I wash the bike often plus get caught in the rain various times. Here is the speaker I went with.
Amazon.com : Infinity Reference 612m 6.5-Inch 225-Watt High-Performance 2-Way Marine Loudspeaker (Pair) : Vehicle Speakers : Car Electronics Amazon.com : Infinity Reference 612m 6.5-Inch 225-Watt High-Performance 2-Way Marine Loudspeaker (Pair) : Vehicle Speakers : Car Electronics
One thing I had done is the fake chrome part painted to match the bike. I think it looks allot better.
Old 12-12-2014 | 05:39 PM
SBates08's Avatar
SBates08
Ok I see that in your post now. Over looked it earlier. Looks nice. How do the 612s compare to the 62.11s as far as sound?
Old 12-12-2014 | 09:34 PM
just plain john's Avatar
just plain john
Bates, I'd bet those grills would fit your 62.11i's
Old 12-12-2014 | 11:25 PM
SBates08's Avatar
SBates08
You may be right. I'm gonna look at using 2 spacers behind each speaker and see if the 62.11 grill will fit it then and be flush. If not I'll figure out something.
Old 12-13-2014 | 01:56 AM
Gannicus's Avatar
Gannicus
Bates - The CVO grills are a little expensive but they look really nice in that location.
Old 12-13-2014 | 07:54 AM
SBates08's Avatar
SBates08
I don't mind buying them if I know for certain they'll fit.
Old 12-13-2014 | 08:28 AM
Gannicus's Avatar
Gannicus
Lol. . They will fit. Ask me how I know. All jokes aside I don't recommend anything I have not tried on my bike or someone elses. If they don't fit I'll personally send your money back. Gan customer service at it's best!
Quick Reply: 2nd AMP Location
