How did you mount your Soundstream pn4.520D amp
I just swapped out my rockford fosgate pbr300x2 for a soundstream pn4.520D amp. Man, what a difference in size and weight. The soundstream is significantly bigger and heavier. I had a bracket made for the fosgate amp and think I will have to just mount the soundstream on top of radio so the fairing fits better. It was a battle last night getting that thing.
So with that all said, how are you mounting your soundstream and what are you using to hold it down or in place?
Did you have any trouble getting the outer fairing back on?
Stop by Home Depo and pick up some industrial Velcro. Use the entire bottom surface of the amp and tack it onto the radio. Make sure you push it all the way back to the gauges. It will not move at this point. If you want to re-enforce the Velcro use cable ties. I've never had to use them but some guys are uncomfortable with just the Velcro. But trust me that amp is not going anywhere. I've rode at least 20,000 miles on just Velcro alone. I used it for my soundstream and my power acoustic . . . It works well.
I did the same. But for added security, wrapped a cable tie around the radio and amp. No issues reinstalling the fairing.
Only thing I found at walmart was industrial strength velcro, 2" wide and 4' long. I cut that in strips and mounted the amp on top of radio. Nice and secure and the fairing fit perfectly now.
Thanks for the feedback and suggestions. Now if it wil only warm up little bit more today I can go for a test ride. Was 30 degrees this morning in Central Florida! 2 degrees more than NY!
I use Industrial Strength Velcro when I don't use my homemade bracket for this amp.
I didn't think it got down to 30° in FL!! Damn.. that sucks.. I guess TX does have the best riding seasons.
Hay Ultra, how you doing? Yeah, one week high 70's next week low 30's. Talk about Bipolar! lol
I got the amp setup and all seems good. Its crazy louder than my old amp. I mean half volume is plenty loud. 3/4 and my ears are running for cover.
One question though. When setting up the imput, with soundstream wires and plug, theres a black wire in middle that directions say to ground. Does this need to be grounded even though there is a ground wire running from battery to amp already?
Other than that very happy with amp except the fm issue. But I think I can deal with that for time being.
