Stereo upgrade done over Thanksgiving weekend
Old 12-01-2014, 04:12 PM
rattracer's Avatar
rattracer
rattracer is offline
Default Stereo upgrade done over Thanksgiving weekend
Many thanks to UltraNutZ and other contributors to this forum. After a couple of months of reading the threads and looking at different choices, I went to Amazon and bought the following: Rockford Fosgate PBR300X2 amp, Infinity Kappa 6.5" speakers, Arc Audio speaker adapters, and the Rockford Fosgate wiring kit. I found mounting brackets to mount the amp above the stereo on eBay from harley08davidson. I mounted and wired the amp on Wednesday evening, and mounted and wired the speakers on Friday evening. Took about 3 hours total, but I'll bet I could do it in an hour now. Didn't take the tank off, after looking at the forum threads, just took out the bolts and raised it up enough to get the 12v hot wire into the wiring channel.
I used the factory speaker grills, so everything still looks stock, but it sounds really good. This is a pretty simple upgrade that you can do yourself on any weekend for about $350. Thanks again to the thread for giving me the information to do it right the first time.
Old 12-01-2014, 04:29 PM
HD_Doobie's Avatar
HD_Doobie
HD_Doobie is offline
Great Job! What bike? Those speakers have a +3 db button on the tweeter. What did you set them at?
Simonizer's Avatar
Simonizer
Simonizer is offline
Congrats, enjoy your new set up!
rattracer's Avatar
rattracer
Default forgot to include bike info
Oops - This upgrade was fairing speakers and amp on a 2013 Street Glide.
Old 12-01-2014, 04:31 PM
tdgriff's Avatar
tdgriff
tdgriff is offline
Nice pics . good for you . once you do it takes half the time your second go around.Good luck
Old 12-01-2014, 06:21 PM
Gannicus's Avatar
Gannicus
Gannicus is offline
Great Job rattracer! Very nice sound with that set up! and thanks for sharing the bracket info. Guys ask me about brackets all the time and Scott doesn't make his anymore.
Old 12-02-2014, 09:49 AM
rattracer's Avatar
rattracer
A +3 db button? Where?
Old 12-02-2014, 09:53 AM
rattracer's Avatar
rattracer
The brackets were about $50. I saw where some guys are just velcroing the amp to the stereo, but I thought that the brackets allow for better heat dissipation, and it's just a cleaner setup. Two screws and you can remove the amp in just a second.
Old 12-02-2014, 10:01 AM
GLACIERPEARL's Avatar
GLACIERPEARL
GLACIERPEARL is offline
Congrats !!
Old 12-02-2014, 10:18 AM
dirtracin23's Avatar
dirtracin23
dirtracin23 is offline
It is a small button that is located on the tweeters. You can either have it pushed in, or popped out. Not sure which position is what as I'm at work and don't have mine sitting in front of me.
More information on this THREAD
Quick Reply: Stereo upgrade done over Thanksgiving weekend
