Hogtunes lids?
If you buy Kickers for the lids. . . you want these:
http://www.rakuten.com/prod/kicker-4...x1EaAgAg8P8HAQ
Sell the PBR300X4 and purchase a power acoustik RZ4.2000D to run your speakers.
The X4 is underpowered to run lid speakers.
If not the kickers take a look at the Pioneer TSD6902R speakers. Both great speakers.
Gannicus led me to my Kicker lid speakers and I'm very happy with my 11KS69's. That said, these 11KS693's have a very good price from Sonic. I like the 11KS series as they use titanium vs. silk for their mids/tweeters. The newer speakers might sound a bit better but my thought is the 11KS series might hold up a bit better in the lid elements? Can't help much with the amp, but the Rockford is safe if you value FM radio reception. The Kicker's are pretty efficient speakers and I'm sure the sound will be MUCH improved over stock. Good luck..
http://www.sonicelectronix.com/item_...693-KS693.html
Pioneers are great speakers - also consider the JBL P963 (I just swapped the Pioneers out with the JBL's and I am happy). JBL's can be found on amazon.
~106usd
+1 - rip the X4 out (not enough power!), replace with RZ4 or Soundstream PN4.520. you WILL most likely lose FM (part/all, or if lucky none)
~106usd
http://www.amazon.com/JBL-P963-3-way...words=jbl+P963
~106usd
By the way. . . The LAST 6 x 9's you want are the hog tunes!
+1 On the JBL's!! Just keep in mind they are 2 ohm speakers and the X4 is not compatible with 2 ohm speakers. That is if you plan on keeping the X4. As Griff said the BT 6 x 9's are also a great option. So many great 6 x 9's out there it's really a matter of preference.
To OP: There are many options out there... all depends on your budget as well.
