Glich in the system
Glich in the system
Ok I've got to ask as I'm far from educated on these electronics. I've got something happening in my stereo. This is an aftermarket Sony head with a small Sony amp and some Biketronics speakers. Everything was working all good until a mishap with turning the volume up. The button must have stuck and the volume got turned almost all the way up. I was able to reverse it and turn it back down almost a second after this happened. Now the radio will be working fine and then just cut off. Then come back off for maybe ten seconds then go back out. Sometimes it will go out for five or more seconds and come back on for a minute. No real pattern to this. What have I got going on here. Have I damaged the amplifier chip in the head possibly? When its on and playing it seems fine as can be. Then just goes in and out randomly. Any fixes or ?????
yep - reset unit - you can pull the main fuse as well...
or if you got the fairing open, disconnect connector from Sony HU (saves you a bit of time to setup "the bike".
Go from there.
I do not really understand "small sony amp"... are you using the build in amp on the sony HU? or separate amp? if separate, disconnect the HU from the amp and then hook up a speaker directly to one of the HU speaker outputs and see if it cuts in and out.
try to elimitate each component (I would do reset via battery, then if still issues, disconnect amp and hook up speaker to HU, then... ???? probably HU kaput...)
Go from there.
My amp is separate or external. I tried the reset thing at the battery. No luck there. I may have started to narrow it down possibly. By the way it has gotten worse and is all but out now. Now sound coming through. I defiantly need to get under the fairing and start checking connections and such. What I was thinking now is my plug and play conversion module from biketronics could be going out. I noticed my hand controls were also acting up and were intermittingly stopping to work. I am on my second one of those modules. The last one I had go bad almost two years ago. Don't recall the sound coming and going like this though. Just the hand controls went out. Anyway thanks for any and all help.
Gannicus I think is on the right track here. pull fairing cap off and watch amp when this happens. If it's going into protect mode (usually has a protect light on it) you've likely damaged a speaker voice coil. When it (voice coil) gets hot it's likely causing your amp to go into protect mode.
guess I should have read further into it to see "other" problems he was having and also your initial post. my bad..
process of elimination is the key to finding your issues OP.
**DISCLAIMER**
Does not work on Girlfriends or Wives. Not © by UltraNutZ
**DISCLAIMER**
