Amp Help
Amp Help
Ok so I bought Boom speakers and wrapped them with poly fill and yes they are considerably better than stock, I am looking for a little more or better sound, can I achieve this by adding an amp, if so what do some of you advise? If not what do you suggest? I know you get what you pay for, but I don't want to break the bank either. So can I add an amp or do I need more ?
I am personally not a fan of the boom speakers...
simple upgrade of speakers to a less expensive good speaker and a "proven" amp (budget) should have been the better route (yes you will need speaker adapter rings for 6.5's and also a 10AWG powerline set; cost total should not exceed 50 bucks for those 2)
RF PBR300x2 is the most "common" used 2 channel amp - it lets you keep FM reception unlike MOST (not all) other Class D amps (PBR is NOT a Class D amp BTW). other options are possible as well...
"blasting" the PBR... pretty sure the BOOM cones will fly by your ears (aka will blow the speakers).
I am not familiar enough with lower Wattage amps (more in the 40-70W / channel range). others will tell you for sure, just wait...
speakers: many choices, Gannicus, UN, GP, ...will chime is as usual....
http://www.caraudiogiants.com/infini...FQsKaQodkCgAfQ
Fosgate amp here :
http://www.rakuten.com/prod/rockford...FUE0aQodLjUAdA
Aprox: $280.00 Bank not broken.
You will have to spend another 50-60 bucks on adaptor rings and a wiring kit. Done.
I'll take the booms if you ship them for free and include a check for 50 bucks LOL....
as Gann mentioned, you can go with the hogtunes amp, but TBH you WILL regret it...
Softy, I would use something like the Alpine KTP445U on those speakers. Just enough power to bring them alive but not kill them.
Course you could always use a PBR300x2 and turn the gains down and then later on if you decide to change speakers, you have plenty of amp to do it with.
I had PBR with Polk MM651 combo as my first upgrade - I LOVED it. still got Polks but we have seen too many issues here with the Polks (tweeter stalk melt down).
I guess I am one of the lucky ones so far. The Polks do sound AWESOME. most will agree here.
go with above PBR and Infinity 62.11i and you will be another happy biker...
