Preparing for an install next week.
Preparing for an install next week when I get my lowers. I currently run a 2 channel PBR300X2 amp pushing a set of Infinity Kappa 62.11i's.
I'm getting two more Kappa's and the Power Acoustik RZ4-2000D.
Looking at the rear of the RZ4 is there such a thing as 4-channel speaker level to RCA adapters, that are any different than what I have. I don't remember the gage but I think it was better than stock (20/22 gage)
Since my Kappa's are 225W peak power, what should I set my gains at if the amp is 250W.
I found it hard to connect the speaker level to the screw-type gold plated terminals on the Kappa's. Wires kept getting frayed. What is the best cables out there to use for my new system?
Also the PBR300X2 amp says it uses (recommended) 50 A fuse, but the RZ4 says 30A x 2. So I need to remove the 50A fuse, and then put in 2, 30 amp fuses, right?
Also, since I'm opening up my fairing I want to address a noise and whine I'm getting from the left speaker. What should I look for?
Just trying to cover my bases. I hate getting in the middle of an install and realize I forgot something.
Try tinning your speaker leads with solder, it keeps them from fraying. 16 gauge speaker wire is what I used. I had a 30 amp fuse on my PBR and simply replaced the amp with the RZ4. The RZ4 is bigger, and won't sit directly on top of the head unit. I spaced mine up some with a piece of 1x4. You'll have to take the 'handles' off the amp. Fuse sizes are dependant upon wire size, #10 AWG is good for 30A.
to OP:
I ran PBR before SS - now RZ. all with the same powerlines (RF 10G set). Totally fine. Amperage usage provided is for MAX usage with usually a test signal like 50Hz. normal music usage, even load, will not get remotely close to the max Amp. you are fine, no worries about the fuse value.
Read the sticky on how to dial in. IMHO it does not really matter if you are using the RCA inputs on the AMP (provided that your HU has RCA aka line outputs; when stock, it DOES matter).
Mine with the 4V line outputs I got set at around 2-3pm / 8-9am (the gain pot meter). this gives me my "max undistorted" around 40+ volume (out of 62) on my aftermarket HU. if I would increase the gain on the amp, the max volume on the HU I could use would go down and v.v. right ?
I got both fiters set to AP. depending on your likings you might want to set the front on HP. that way you are not "slamming" your front speakers...
to OP:
AP - All Pass
LP - Low pass
Most of us either run our speakers HP set at 80-100 hz or AP.
AP is the same as flat or full pass depending on the nomenclature of the amp. AP is mostly used on our systems because most of us run full range speakers without a sub and we need all the low frequency output the speaker can give us. LP is obviously for subs if you got em and filters out the high notes. HP set at 80 Hz filters out all the low notes below 80 hz. or better yet the unnecessary low notes. AAWAV is probably sleep. . .lol
looks like you pretty much have it covered.
