Tell me what you think.
Right now I have the factory HU, Polk MM651s, and PBR300X2. Im geeting ready to go to a aftermarket HU and want add speakers to my lowers. What do guys think about running 4 Kicker 40CS654 wired in parallel off the PBR? The amp spec say Im pushing 150 watts per to the 2 Polks and if I go to the Kickers its going to be about 75 watts to each speaker.
Thanks that's what I was afraid of, I didn't want to take a step backwards. So maybe a set of the Infinity Kappas in the lowers and the Cerwin-Vega B4 is rated at 150X4 at 2 ohms or the SS 520.
Knowing how Fosgate rates their amps, you're probably getting more than 150 watts at 2 ohms from it. Check you're birth sheet.
Both are good amps. The B4 is new on the scene but the people that have them like them. Beware the possible FM loss with the SS. You could always add another pbr too.
I would like to run everything up front off one amp that way I can add 6X9s Hogtunes lids later. So fairing and lowers of a B4 then find a set of 2ohm 6X9s and use the PBR for them? Do you think the B4 and the PBR would both fit in the fairing if I use the Hogtunes bracket?
also consider PA RZ - see my sig.
I run Polks in the front and with the RZ they pound PLENTY...
run the front with RX and keep the PBR around for rear of the bike when you are ready...
as Pioneer mentioned - if you really care bout FM, you need to be careful with the SS or RZ (my RZ still has most of the stations; it is a hit or miss with most of the Class D amp)
Good plan! If you want a nice set of 2 ohm 6 x 9's check out the JBL P963's awesome speakers for clarity and bass!
