Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
Shotgun on order
Old 08-21-2012, 06:42 PM
KrakkyDoo's Avatar
KrakkyDoo
KrakkyDoo is offline
The instructions say to drill the holes on the bottom of the trans. This step was not required on mine and I don't believe will be on your 2011.
I'm glad I tried the bolts before I went to drilling, could have been a bad deal.
Old 08-21-2012, 10:41 PM
norcal's Avatar
norcal
norcal is offline
thanks everyone, yeah i just had the service done on it so i should be good on the tranny fluid for a few thousand miles, cant wait
Old 08-22-2012, 10:00 AM
Ash16's Avatar
Ash16
Ash16 is offline
This is a good write up on the install norcal https://www.hdforums.com/forum/air-s...ad-how-to.html. Make sure you post before and after pics. You're gonna love the new ride!
Old 08-22-2012, 03:21 PM
I Corps's Avatar
I Corps
I Corps is offline
Question
I am putting chrome covers and switches to replace the black ones. Has anyone used the H-D Auxiliary Accessory Switch Housing Kit to run his shotguns?
JD, please jump in if you see this post. Thank you.
Old 08-22-2012, 05:40 PM
J.D.1's Avatar
J.D.1
J.D.1 is offline
Former Sponsor
Wiring switches to a handlebar location is alot of labor but possible, try factory mount first and you will find it an easy install and convenient location for adjusting the suspension. You want my opinion, just ask.
Old 08-22-2012, 06:17 PM
I Corps's Avatar
I Corps
I Corps is offline
Thank you JD. I will mount the switches on the horn bracket first. I just thought it would be cool to have them on the handlebars.
Old 08-22-2012, 09:06 PM
J.D.1's Avatar
J.D.1
J.D.1 is offline
Former Sponsor
The cool factor is always a consideration, but you need to be familiar with the factory switch operation in order to have a clear plan of how to wire into bars. If you decide to custom mount switches or wire into your switches, I can provide a color coded extension in order to simplify your customizing.
Yeti71
06-18-2019 04:03 PM
kaiser343
10-21-2013 06:56 PM
kalamitty
12-23-2011 03:47 PM
jammer1
12-29-2006 05:12 PM
Shift_4lo
01-12-2006 12:18 AM
Quick Reply: Shotgun on order
