Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
shotgun shock install question
Old 07-15-2011, 07:49 AM
Sofmech's Avatar
Sofmech
Sofmech is offline
Default shotgun shock install question
I'm sure i will answer my own question but do you have to have some sort of lift to do this? Got mine in yesterday, super fast shipping might I add, and I am going to install this weekend. I am going to assume I will need some sort of lift and then a block under the rear tire to keep it from falling. Anyone have a trick to do this without a lift? I've been looking on craigslist for one just to have but no luck so far. Probably going to order one from harbor freight. Just checking to see if anyone has a trick until I get my lift. Thanks guys.
Old 07-15-2011, 07:55 AM
fcsallan's Avatar
fcsallan
fcsallan is offline
you could block the bike up under the frame and use a floor jack under the rear tire to adjust the height as needed, but I would say that was anything but smart.
You can pick up a decent jack for under $150.
Old 07-15-2011, 08:17 AM
aaron8771's Avatar
aaron8771
aaron8771 is offline
I got a jack from Sears for 80 bucks. Get one. You'll use it all the time
Old 07-15-2011, 08:45 AM
Sofmech's Avatar
Sofmech
Sofmech is offline
Of all places Sears never even crossed my mind. No better time then now to buy a lift.
Old 07-15-2011, 09:28 AM
tunaman's Avatar
tunaman
tunaman is offline
A lift for your bike and a small jack for the tire will make the job far easier. Harbor Freight also has some cheaper lifts that work well, as do the Sears model. Get one and you'll thank yourself many times over.
Good luck! You'll LOVE your Shotgun Shock once you get it installed - WELL worth the work!
Roger
Old 07-15-2011, 12:50 PM
J.D.1's Avatar
J.D.1
J.D.1 is offline
Former Sponsor
Default Use a lift to be safe
After bike is on a lift make sure to use tie downs to secure bike to lift. Check out harbor freight high position mc lift, 99887.
Old 07-15-2011, 01:18 PM
z06elmo's Avatar
z06elmo
z06elmo is offline
There is a thread on the main general section about a sale on the harbor freight lift. I got mine for 59+ Tax with coupon. It works and does the job on my deuce.
When i changed out my shocks, I used the lift to get the bike up. My bike was lowered already so I had to roll the rear tire on a 2x6 and put the sidestand on a 2x6.
Once lifted in the air, i got it high enough then put two car jacks under the frame (one on each side) in a location so I could access the shocks and bolts easily. I used a car jack to lift up and down the rear tire to move the swingarm.
The biggest PITA is loosening the 3/4 (19mm) bolts that hold the stock shock in place. try a combo wrench and a BFHammer.
Old 07-15-2011, 01:25 PM
WARG's Avatar
WARG
WARG is offline
+1 on the Sears lift for $80. Had mine 5 years.
Old 07-15-2011, 01:46 PM
Sofmech's Avatar
Sofmech
Sofmech is offline
Half way done with my ride today. Heading to the all mighty Sears when I get back.
Old 07-15-2011, 03:39 PM
keno's Avatar
keno
keno is offline
harbor freight high position mc lift, 99887 is and has been on back order for a while. I ordered mine about 2 months ago, then was notified it wouldn't be available until July 8th, now they tell me August 5th.
Update: This lift is again available and not on back order.
Quick Reply: shotgun shock install question
