Just ordered my shotgun shock today and looking for some ideas as to where to mount the switches. I know most have mounted them by the horn and I have seen a few that mounted on the speedo housing, but I was wondering if anyone has tried something different?
I mounted mine on the back of the upper fork cover. If you look closely you'll see the two toggles (air suspension and headlight). I also mounted two small led lights there (oil and neutral lights).
Mine are on top of the horn, jim I like your location but Idon't have the coil there. I do want to move mine as I have hit them by accident and killed the battery once. When it's hot I have to push the compression releases in and bumped them.
The switches and mount are included. The mount is meant to go above the normal horn side mount.
At first I think JD was installing or suggested you install them through holes drilled into the side of the dash console.
