Been thinking about a Shotgun shock...
Okay, I am going to be getting my shotgun hopefully tomorrow am or Friday. I can now sell them as well. If you need pricing please PM or email me at DREW@DRVTWIN.COM
How much has everyone paid for theirs?
Drew
Drew
I am too. I just need to find time to get to his shop, pick it up and install it. It will most likely be installed Friday or Saturday.
I will lay out some of the differences here right now for those who are unaware. Platinum is a fine system in it's own right and each system has it's good points. My favorite thing about Platinum is that since the shocks are individual I am able to drain my tranny oil without dropping anything out of the way. The shotgun is a one piece unit and two of the shock bolts must be removed to swing it out of the way for tranny oil changes. Not a big deal really, but if you service your own bike it does take longer.
I need to wait until I have my shotgun in hand (lol) to elaborate any further on anything else comparison wise as I have not seen it in person yet.
Also, if you guys have any questions please feel free to call JD direct 323.359.4914 as he can answer them as well. He is extremely knowledgeable on the subject as he designed the system himself. Once I have mine you can call me too. I take all calls whenever as customer support is a very important part of my job. Ask anyone who has called me at 8PM, they know. JD is the same.
Drew
Drew
Drew
Drew
I have the Shotgun shocks and if there is one complaint to make is that they are extremely bouncy. The roads here are crap in most places and unless I really make them very stiff I bounce all over the place, which I suspect is true for any air system.
The good thing is that I can raise the rear fender while riding and slam it when stopped for that dropped look!!!
my 0.02$ opinion...
Robert
my 0.02$ opinion...
Robert
my 0.02$ opinion...
Robert
my 0.02$ opinion...
Robert
thanks!
Drew
Yes, I actually spent the most time on the wiring. I did not want to install the switches on the dashboard, but eventually put them on the handlebars, using the aux switch housing from HD. This required the leads to be lengthened, so soldering and shrink covers required.
JD provided as a special service the tap and drill, as they are practically impossible to find here. You need to enlarge a couple of holes underneath the transfer case, drilling in to Al, so very easy. If you have basic mechanical skills you can do the whole install in a few hours, depending where you put the switches...
There is a relay that can be mounted on the right side of the gearbox, using a 5/16" bolt (not supplied).
See also on my blog for some more pictures and info...
Robert
Robert
