Shotgun Air Ride
#71
So whats the change in the NEW compressor? What was wrong with the old ones?
Thats gonna look kinda of FuGLY with that compressor not hidden..Too bad. Looks like Shotgun just took a step back in appearence.
So i take it you now own a second or third generation Shotgun shock?
#72
Not sure why he switched compressors, we didn't really get into that. It does appear to be bigger than the old model from the pics on his website. I don't know what generation it is... It does have cooling fins on the head, that's the only thing that looks different to me. Once the exhaust is on it will completely cover up the compressor. I'll post some pics of the final build.
With guys runnen true duals like i have that compressor would stick out like a sore thumb....As true duals run parallel to the bottom of the frame. I have a clear view to that section of my bike and a compressor sticken out would be UNEXCEPTABLE.
Well i guess if your runnen true duals go with a Platinum bleed/feed or turn that compressor around....Atleast we know....
Please let us know how you like that NEW styled compressor.
Thanx ty for the updates.
Here is a old pic i had but as you can see this area with true duals is completely opened up.
#73
After looken i noticed that your hose fitting are different as well as cooling fins.
Attachment 89078
Attachment 89078
#74
You may want to try and turn that compressor around so all you see is the cann...You never know it might fit.
Ok here is a "NEW pic" ...compressor is hidden....you have to bend down to see it. It doesn't stick out from the sides at all. If the compressor stuck out...IMO... i would be goen a different route.
excuse the bad pics...
notice the second pic and sticker is to the left
#76
no problem, just put mine back together after doing my offset work.....was thinking SH#@* do i have to go through that all again!!! lol
#77
#79
#80
The one you have is probably the smaller version. There's nothing wrong with the smaller compressor. JD told me that he hasn't started shipping the larger one's yet, however, he had been installing them and that I received one of the first one's. The other riders all have the small compressor and may even like it better because of the way it hides under the trans. If you look on the shotgunshock website and compare your compressor to the one on the instructions vs. the one in my install pics, you should be able to tell which one you have. I won't know what the performance difference is in the two compressors but I will take some video and post it on here so you can see how it performs and compare it to your compressor.
