Air Suspension Recommendations
All, just got through searching the forums for good links for air suspension recommendations, but came away with little other than a real good thread on the SAS setup. I'm posting this in the Softail forum, as I'm sure the experiences differ between the family models to some extent.
I've decided I want to go with air suspension soon, as I ride far too often mixed (75% solo, 25% 2-up) to be adjusting the shocks for each ride. I stiffened the stock settings up a bit to accommodate my wife and saddlebags, which was about right. Now when I ride solo it is too stiff for my preference.
Can you guys give me some good recommendations as far as what quality air suspension systems are available, so I can narrow my research a bit? I'm not too interested in the lowering aspect, although I believe that will be a side benefit, but I don't want to get a setup that will turn out to be a perpetual headache.
Thanks to all in advance for your input!
Roger
Roger
Try this link for a number of systems available. I'm sure you will get many opinions on which is best.
http://www.tejasthumpcycles.com/Part...nd/rearend.htm
Thanks for all the opinions and input so far, folks. It's appreciated.
I do really like the concept of the SAS unit - looks clean, simple and well-built. Anyone have experience with the ride? What are the most comfortable units out there?
Also, what mounting options are there for the late-model Fatboys if I get a compressor unit?
Roger
Roger
The SAS unit is very nice (for convenience factors), but pricey. Hi/Low systems run about $1k, Legend runs about $1100 - 1200 (depending on black/machined/chrome shocks), and SAS runs about $1600. That's a big jump, in my humble opinion. Now, I do like the idea of the compressor being built in, and not having exposed air hoses, such as the Legend System.......but I can deal with the risk of blowing a hose, and having to ride home "rigid" to save myself $500 plus labor. Just my thoughts.
