the bike has the ability to use homelink. you need a module and mounting bracket. it goes behind the front fairing about the headlight/amp. dealer will need to turn it on.
let me guess the minimum charge will be 100 bucks to use Homelink. I need to check it out but do I have to buy any Harley Davidson equipment and have it put on the bike?
If you want to use HD “flash high beam to open” then yes, you need a module $210 and a mounting bracket, don’t know the price, cause you can only order it at the dealer, when searching the website it returns “nothing found” for that part number. You can install it yourself but dealer has to flash bcm. So all in I’d say close to $300.
I have homelink added to my 24. It’s not flash high beam to open, you click the icon on the IFCU and choose which door to open (if you have more than 1 garage door). Mine is also a road glide….it is kind of rogue too.
thanks for the info. Did you install it yourself or have it done at the dealership? Is it bulky or take up space on the bike?
double tap the high beam (flash to pass switch) and it works
