2024 Road Glide Gas Tank Removal
It's pretty easy. Your going to need a few tools. 1/2" socket, swivel, 12" extension, T27 torx bit, ratchet and a small set of Allen wrenches. Remove seat first then you will find two bolts at the rear of the tank to remove. Then remove the dress piece in the center of the gas tank with the T27 bolt at the rear by the two bolts you just removed and a small allen head screw up from, then lift the dress piece. Now there are two small hoses to remove from the gas filler area of the tank. Once those are off there is a quick release for the fuel line and a set of wires from the fuel pump that run under the tank by the hose you just unhook to a plug, unplug it. There are two more bolts on the front of the tank, one on each side cover by a rubber cap on each. Remove the cap simply by pulling them off ans it doesn't take much force to get them off. Remove the last two bole from the front then lift the tank up and rearward as you remove it.
The following 5 users liked this post by Steve Cole:
DC2009EGUC (10-10-2024),
DeeRoe (10-10-2024),
drc68 (10-11-2024),
hdatontodo (10-10-2024),
twoglides13 (10-11-2024)
h-d wrencher (10-11-2024)
BrandonSmith (10-11-2024)
The following 3 users liked this post by Steve Cole:
By the way the fit and finish of these new 2024 model are so night and day compared to my previous 2021 RGS, especially the front fairing fits like an expensive leather glove, that gas tank fits & seats nicely on the frame, and the side panels and saddle bags fits so tightly and no loose parts to rattle or vibrate, so glad to own a 2024 MY bagger and a CVO/ST to boot...lol
