2024+ Touring Models Discuss the currently offered Touring Models
Axel lube?
Old 07-13-2024, 08:19 PM
81shovelhd!'s Avatar
81shovelhd!
81shovelhd! is offline
Default Axel lube?
Can white lithium grease be used on axels?
I'm reinstalling my front wheel and that's all I have at the moment?
If not, what do you recommend?
Tx!
Old 07-14-2024, 06:52 AM
foxtrapper's Avatar
foxtrapper
foxtrapper is offline
Received 1,570 Likes on 1,032 Posts
Eh, it's the bearing that spin, not the axle. Grease is basically there to ease disassembly and assembly and prevent rust.
Not my choice of grease, but it should be just fine.
KK0G (07-15-2024)
Old 07-14-2024, 08:31 AM
Rounders's Avatar
Rounders
Rounders is online now
Received 2,179 Likes on 1,727 Posts
Wouldn't you just use anti seize?
The following 2 users liked this post by Rounders:
DeeRoe (07-14-2024), gabhart (07-14-2024)
Old 07-14-2024, 08:34 AM
BrandonSmith's Avatar
BrandonSmith
BrandonSmith is offline
Received 3,019 Likes on 1,795 Posts
What bike?
Old 07-14-2024, 08:47 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,876 Likes on 4,082 Posts
You need to use a water resistant anti-seize grease. White lithium probably won't do the job as nearly as well.
Harley uses Loctite brand. Permetex has one. OMC boat propellers shaft anti seize is what I used because I had it. Soap and water won't even get that one off your hands it's so water proof.
OMC is long gone but it was a water proof product.
Old 07-14-2024, 08:59 AM
470004's Avatar
470004
470004 is online now
Received 15,952 Likes on 6,597 Posts
I put a very light coat of anti-seize on the axles to help prevent rust and seizing.
TriGeezer (07-14-2024)
Old 07-14-2024, 09:26 AM
Rounders's Avatar
Rounders
I slather anti seize on like it is ky jelly,
Old 07-14-2024, 09:51 AM
81shovelhd!
Ok......now I'm confused.
It's the bearings that spin, not the axel.
So why would anti seize be needed for the axel since it remains stationary?
Also......my bearing is good.
How do I lube/oil that since it's installed?
Old 07-14-2024, 09:55 AM
Rounders's Avatar
Rounders
Front and rear axles I piut on anti seize, I am pretty sure it is in the manual. Slide it into bike. Makes threads are clean. Wipe brake clean if needed. It will make it easier to pull out. Anti seize is not really a lube, just helps you remove. I use it all kinds of stuff on bikes and truck. And anything else that I want to take apart someday. Nuts on metal sinks.
Old 07-14-2024, 10:57 AM
Bass Player's Avatar
Bass Player
Bass Player is offline
Received 1,941 Likes on 1,065 Posts
Use grease on any bearings! Anti seize is NOT a lubricant for cryin out loud.
Quick Reply: Axel lube?
