I've been very happy with my 2024 SG except for the rattle coming from the back end on deceleration. I believe it is coming from the plastic tail lights. Has anyone else noticed this? BTW... The exhaust system is stock, everything is tight.
Update: Corrected two items. It's a tight ride now. No more rattles. The metal turn / brake light brackets are mounted directly to the metal fender. I installed some 3M 3mm adhesive foam to the light mount. This should also protect the painted fender. Second was the cross over pipe. The pipe is oval in that section and although the clamp was tight, there was movement / rattled when bumped. One wrap of header insulation tightened this up.
