Notices
2024+ Touring Models Discuss the currently offered Touring Models
Street Glide Handlebars
Old 07-08-2024, 03:33 PM
sumncguy's Avatar
sumncguy
sumncguy is offline
Originally Posted by Street79
WRT to fitting the HD Tallboy bars did you get away with the existing harness, clutch cable etc?
cheers Mike
Yep no problem with cables or wires. No replacement necessary. All mine are stock.
  #32
Old 07-08-2024, 03:39 PM
Street79's Avatar
Street79
Street79 is offline
6th Gear
Awesome thank you!
  #33
Old 07-08-2024, 03:42 PM
BrandonSmith's Avatar
BrandonSmith
BrandonSmith is online now
Received 3,136 Likes on 1,849 Posts
Hi all from the UK. WRT to fitting the HD Tallboy bars did you get away with the existing harness, clutch cable etc?
cheers Mike
Yep. All existing wiring, clutch cable, and brake line work with the HD Tallboy bars. You WILL have to remove the two retainers that hold the clutch line and brake line to the triple tree, so that you have enough slack in those lines.
In the video below, I show the process of replacing the bars without removing the fairing. I do not detail what I described above because there are so many variables depending on the bars that are being installed.
To remove the clutch and brake line retainers with the fairing in place, you will need a T27 bit for a 1/4” hex driver and a way to turn it. I turned my T27 bit with a 1/4” end wrench and it worked just fine. You basically need a right-angle T27.
LJHOG (07-08-2024)
  #34
Old 07-09-2024, 08:42 PM
1 Broke Dad's Avatar
1 Broke Dad
1 Broke Dad is offline
Default Installed
Just installed the tall boy handlebars. Was not hard to install. I highly recommend them. Much more comfortable than stock.
BrandonSmith (07-09-2024)
  #35
Old 07-12-2024, 03:09 AM
Nutty's Avatar
Nutty
Nutty is offline
Originally Posted by 1 Broke Dad
Hey everyone. I picked my brand new Street Glide this weekend. I like the looks and layout of the Street Glide over the Road Glide but man do I like where the Road Glide handlebars put your hands. What size handlebars would I need to get to mimic the Road Glide location? Thanks for your input.
my exact thoughts 1-BD,
I fabbed up a mule today to get the bars more like the RG. I’ll bend a copy next week. I even took some sweep out of the bend.
  #36
Old 07-12-2024, 07:29 AM
Spider3223's Avatar
Spider3223
Spider3223 is offline
I think the RG bars are 11 inches I have heard. Also the bend in the road glide bars is more flat than the street glide which makes a huge difference. Tallboy bars are going to be about 10 inches but they have the same bend as the stock street glide bars (more pullback than road glide bars).
don’t really have an answer but maybe this might help.
addendum: I meant this as a reply to Broke Dads post. Can’t figure out how to delete a post on this.
  #37
Old Yesterday, 12:32 AM
uwiik's Avatar
uwiik
uwiik is offline
Any update on this awesome looking prototype?
  #38
Old Yesterday, 07:11 PM
Nutty's Avatar
Nutty
Nutty is offline
Originally Posted by Taxgod4u
How do you remove the drawer?
just let it fully come out by itself until it hits the stop, then slightly lift the front face while firmly pulling the tray out.
  #39
Old Yesterday, 07:16 PM
Nutty's Avatar
Nutty
Nutty is offline
yep. version 1.1 finished and tested. It’s a fraction too straight.
Needs a tad more sweep. I’ll take 2-3 degrees out and retest.
  #40
Old Today, 02:07 AM
uwiik's Avatar
uwiik
uwiik is offline
it’s already looking absolutely sick, very aggressive looking… moto bar position without the moto bar problem… love it!!
Zakk13
05-02-2024 08:30 AM
TravelingTall
07-21-2023 11:10 AM
TravelingTall
Harley Davidson Videos
03-14-2023 01:38 AM
jeffreyjames
04-04-2011 08:14 AM
jims79flh
03-23-2011 09:13 PM
Quick Reply: Street Glide Handlebars
