Oil Pan Replacement - Two Questions
Question 1.
Can it really be done in-situ?
The factory manual just describes putting the bike on a lift, draining the oil, and removing the pan. But that frame strap going across under it prevents the pan from being dropped more than about 3/8ths of an inch.
So if any of you have already done this job, can it really be done this way? Just drop it a little and slip it out?
Question 2.
Revised oil pan and fasteners.
This is the Harley tech bulletin that explains it: https://static.nhtsa.gov/odi/tsbs/20...42096-0001.pdf
So newer larger flanged bolts for the newer oil pan. Fine.
BUT...that part number doesn't exist according to Harley. It's not listed in the on-line parts catalog, and you can't find it by searching for it.
So what the heck happened? Does anyone know why Harley would put out a tech bulletin saying to use these newer bolts that you can't get?
Question 2.
CoolBreeze3646 (Yesterday)
Are you changing your oil pan because something is wrong with it or just because you saw this bulletin? Sounds like the old pan was just fine, the MOCO just wanted to use bolt that had a little more surface area to them.
OK, I saw your other post, oil pan has a hole in it.
https://www.hdforums.com/forum/2018-...der-roads.html
