Symptoms of a failing starter
I am starting to think I have an issue with my starter. Every so often, when trying to turn the bike over, it'll just crank and crank but won't kick over. It's not a constant issue and, so far, hasn't left me stranded but I am concerned that if my starter is beginning to fail then it's just a matter of time. Is there any specific symptoms a starter would begin to show when it's failing or is it kind of an all or nothing scenario where it just works until it doesn't?
The following 2 users liked this post by nevil:
CatEyeDallas (05-30-2023),
OldMike (05-24-2023)
The following 2 users liked this post by strych9:
eighteight (05-24-2023),
NZLowrider (05-24-2023)
I was talking to one of the service writers one day and they brought out the little piggyback tester the techs use and it came back at like 12.4 needed to crank the bike over. I haven't had them pull it out and throw it on their tester due to how much of a pain in the *** it is on the newer Softails.
The following 6 users liked this post by strych9:
702 (05-24-2023),
Kadab (05-24-2023),
nomoreyellowfootprints (05-24-2023),
NorthWestern (05-24-2023),
and 1 others liked this post.
Sounds like your starter is doing great. My guess is how you trouble shoot, you need another engine for the starter. Or start with new new fuel, then plugs and air filter.
If it clicks and hesitates and then speeds up cranking and starts, the battery is weak on charge or amps.
Usually the big contact in the starter solenoid goes first. Your battery is good and you here small relay click but nothing else.
So many variables however, one needs a few pages for each thing.
Are we talking about a 2021?? If so you have to be a tin man's cash cow for sure.
For sure on anything EFI, hit starter and don't let up. Letting up too soon only makes starting harder for the ECM and FI to figure what's going on.
And each hit on the start is a start count for that large contact. Four pushes on the start button for one actually running engine is four starts.
Why some don't get much life from a starter.
Sounds like compounding problems:
1 - cranks without starting.
> If the starter is cranking strong then there must be a Luther reason the motor does not start. Ignition or fuel.
2 - sometimes ya push the starter button and nothing happens.
> could be a bad ground to the transmission, or power cable to the starter.
> maybe connection/power to the starter solenoid
> bad start switch
> if you are trying to start in gear, whilst pulling the clutch in…maybe bad clutch switch.
> if you are trying to start in neutral, maybe bad or intermittent neutral switch
> operator error…did you inadvertently shut off the run switch?
Thats all I have..
> bad start switch
Thats all I have..
