2018+ Softail Models Breakout
Symptoms of a failing starter
Old 05-24-2023, 06:59 PM
NikkiZXXX's Avatar
NikkiZXXX
NikkiZXXX is offline
Originally Posted by dmonger
I was talking to one of the service writers one day and they brought out the little piggyback tester the techs use and it came back at like 12.4 needed to crank the bike over. I haven't had them pull it out and throw it on their tester due to how much of a pain in the *** it is on the newer Softails.
I'm kinda having the same issue, and now have my battery at Harley to test. I'm no mechanic, but I will say getting the battery out really isn't that bad. 2 worst parts are: 1. Make sure to use needle nose to take out/put in the positive screw, and 2. It's a tight squeeze to actually pull the battery itself out after you get it disconnected. You just have to kinda rock it back and forth while lifting it up. Make sure the strap under the battery gets placed back right. (The strap will stick out making it much easier to remove the next time)
Old 05-24-2023, 11:59 PM
Glenn Gorman's Avatar
Glenn Gorman
Glenn Gorman is online now
Received 1,189 Likes on 560 Posts
Doesn't anyone pull a spark plug wire any more to see if the bike has a spark?
Island Dude
Ironhead
20
02-08-2024 06:07 PM
hardheaded
Shovelhead
07-01-2013 12:11 AM
cruiser66
Exhaust System Topics
08-09-2010 12:33 PM
dirty78ironhead
Ironhead
05-20-2008 04:49 PM
Quick Reply: Symptoms of a failing starter
