Tire Pressure (there’s an app for that)
I was considering getting one of these, but my tires leak air so slowly that for me it's a solution looking for a problem.
Plus if my rear tire starts getting lower, I can tell by how it rides.
Below 36PSI its very noticeably different than the 42PSI I run it at normally.
I check my cold tire pressure every 3 weeks, and totally forgot about a TPMS.
I’m very happy that such a product is available at this price point.
Goose_NC (01-11-2023)
Bit of advice!
From the reviews on Amazon (and my own personal experience with the same type product from Garmin) on bikes like my Ultra which has long rubber valve stems you should replace them with a metal stem before using these as recommended by Garmin and FOBO. I ignored that and while testing mine, when I hit about 75 mph the rear cap caused the stem to bend enough to strike the rear brake caliper causing immediate deflation. I now have and also recommend the metal T valve stems which also greatly help in reaching the stem to fill the tires.
Besides that, I love being able to check and monitor the tire pressure easily.
The following 5 users liked this post by elPrez:
Calif Fat Bob (01-11-2023),
cannot (01-11-2023),
cycleman11 (01-11-2023),
stixvrad (01-13-2023),
Tundra9880 (01-13-2023)
Bit of advise!
1: I don’t doubt you but I did a fair amount of review reading and never encountered anyone reporting what you are describing. I think the most complaints came from folks claiming they couldn’t get the caps to bind with the app and they were the same folks who failed to realize that they needed to disassemble the caps first to remove the coin battery insulators and…
2: My valve stem would have to be about 2-3” inches longer than it is to even come close to making contact with rear brake rotor or cylinder…
either way I’m happy to have what I have for the price I paid and once again I’m sorry for posting here.
The following 2 users liked this post by JINKSTER:
JustinC13A (01-25-2023),
M Oclaf (01-11-2023)
The following 12 users liked this post by smitty901:
Bricklayer (01-12-2023),
Doublefelix (01-12-2023),
downzero (05-13-2023),
eighteight (01-11-2023),
and 7 others liked this post.
I have the Fobo Bike 2 on all my bikes, yes it is more expensive then the Chinese ones and I even own a set of 4 from these Chinese stuff on my Quad but the reason why I opted for the
Fobo was that I can see all my bikes seperate in the same app. Currently I have 5 bikes equiped with the Fobo and it is nice that it just uses 1 app to see them all. You can name them
and it is easy to see the results. Now the Chinese one function just as well but it didn't have the option to see more ythen one bike / car in the app.
The following 2 users liked this post by MoneyFor:
JINKSTER (01-11-2023)
1: Are all your FOBO caps on metal stemmed valves?
2: How long have your oldest cap’s been in service?
Okay…two things.
"Reviewed in the United States on June 10, 2022
Had them on 2 weeks on brand new tiers and I tore out my valve stem from smacking against my break caliper on my bike! There is a 2 inch gap and they still hit. Very lucky no one got hurt just learn from my experience 👎👎👎👎👎👎"
and
"Reviewed in the United States on September 9, 2022
This product cut my valve stem down costing me more money to repair the flats than it is to buy the product buyer. Beware, do not buy this product "
I don't agree with it being the fault of the product, it's on the user in these cases. I think it's a great idea but warn those with long rubber stems, like on mine that were off of an 07 Street Glide which in addition to being long are also at an angle so the centrifugal force of the spinning wheel at speed, causing it to bend enough to strike the caliper
