2018+ Softail Models Breakout
Reconnecting Or Replacing Handlebar Wiring Solution
Old 12-14-2022, 07:46 PM
JD3's Avatar
JD3
JD3 is offline
Default Reconnecting Or Replacing Handlebar Wiring Solution
Hey Fellas,
So it appears I have a pinch wire after doing my bars. Does anyone have a good way to find and fix? I was thinking about replacing the wiring with a guerrilla cables ultimate kit and soldering them in. Not sure what the best solution would be... Looking at Harley parts, it doesn't appear to be plug and play into the controls.
Old 12-15-2022, 10:01 AM
stormin08's Avatar
stormin08
stormin08 is offline
there are tools for chasing these gremlins, not sure if it warrants the purchase for a one time deal.
if time allows, you can always disassemble the bars, reconnect wiring and start wiggling...they are coming apart anyway for new wiring
Old 12-15-2022, 10:52 AM
Architect's Avatar
Architect
Architect is offline
Received 5,456 Likes on 2,781 Posts
A simple continuity test will help you figure out which wire was compromised. Then fix the wire, solder, crimp connections, what ever works for the situation.
No reason to change an entire harness, good luck.
Old 12-15-2022, 11:24 AM
downzero's Avatar
downzero
downzero is offline
Received 2,049 Likes on 1,136 Posts
I recommend removing the switches from the ends of the bars now and looking for it. It'll probably be where the switches clamp on the end of the bars.
badaim
Electrical/Lighting/Alarm
02-22-2022 01:38 PM
BrandonSmith
05-15-2020 07:30 PM
ryan9977
02-08-2020 07:14 PM
gliderman
03-18-2008 07:09 AM
BadPiggy
03-17-2008 12:22 AM
Quick Reply: Reconnecting Or Replacing Handlebar Wiring Solution
