How to remove bottom rh switch housing?
Hello people.I haven't removed one of these before so best to ask.After the top housing is removed and I separate the master cylinder from the bottom housing what's next?Does the housing just remove from the switches and wiring or is it the 2 screws (1 in diagram)holding the cabling in that needs removing 1st?
murphc13 (09-30-2022)
I tried that yesterday but it seemed the bottom housing 10 was stuck to the swithe.I didn't yank it as I didn't wanna damage anything.
yes but when the housing and switches are moved apart from the lever perch/master cylinder does the bottom housing just pull away from the switches?I dont wanna yank and do any harm
No, just the screws numbered "2". The bottom of the switches isn't going to move far because the electrics that run through the bars are connected to it. But you will get some movement. Watch out for the front brake light switch between the brake lever and switch housing.
