What's the story with the Clutch Switch?
Half the time my Heritage won't start while in gear/clutch in. I have to put it in neutral to get it to light. I've seen plenty of post on the subject, but mostly from those with touring models and trikes. I'm aware that the touring/trike models have a TSB (M1468) out on this subject...
https://static.nhtsa.gov/odi/tsbs/20...35420-9999.pdf
See that for the touring models/trikes they replace the LHCM and the clutch lever.
What's the story on the Softails? Anybody had the problem? Any simple solutions?
hav had 2 replaced under warranty. ('18 Heritage 114) finally a tech told me rain gets in there, last time put some clear silicone in cracks around bars. no problem for 2yrs now. btw, I had that happen on a 2017 Roadglide M8, it is somehow connected to the ecm on the tourning models. it will drive you crazy, idling up and down and lugging.
So... I had a moment today to take a closer look at this. The switch appears to still be functioning fine. If I use my finger to depress the switch fully, the bike will kick over. If I use the clutch lever, nothing. I've got Avon grips on the thing. Apparently the grips have a larger circumference than stock, preventing the clutch lever from fully actuating the clutch switch.
Hmmm... I like the grips... Solutions? Shim with something or set screw...or...
Had to have it replaced under ESP at I think around 28,000 miles.
No issues since.
Parts Giant
Parts Giant
03-20-2020 01:31 PM
wesshipman
Touring Parts
03-04-2018 08:13 AM
kdrperformance
Touring Parts
11-13-2014 04:00 PM
