2018+ Softail Models Breakout
Transmission dipstick change
Old 08-10-2022 | 09:48 PM
P51Driver's Avatar
P51Driver
Default Transmission dipstick change
Well I just picked up my new 2022 heritage and I was going over all the oil levels checking to make sure all the fluids are at the correct level. In the past with my 2018 and 2020 softails checking the trans fluid was a real bitch as I could never see the fluid level on that damn chrome dipstick. Also I always had a difficult time getting the trans. dipstick to thread back in to the threads on the trans housing. Well I am pleased to say that on my new 2022 Softail Harley has changed to a black plastic trans dipstick. This does two things. Now I can actually see the fluid level on the dipstick. And now it is much easier to get the dipstick threaded in to the trans housing threads.
Thanks Harley!
The following 3 users liked this post by P51Driver:
Dan89FLSTC (08-10-2022), HD676 (08-11-2022), Las Vegas Jim (08-11-2022)
Old 08-11-2022 | 05:24 AM
Steve Sportster's Avatar
Steve Sportster
Good. I dislike the dipstick on my 2018 Heritage for the reasons you cite above. Does the new dipstick also require a large Allen key to remove it?
The following 2 users liked this post by Steve Sportster:
Las Vegas Jim (08-11-2022), P51Driver (08-11-2022)
Old 08-11-2022 | 08:26 AM
gtrb's Avatar
gtrb
Congrats on your new ride.
Old 08-11-2022 | 09:05 AM
P51Driver's Avatar
P51Driver
Yes it still requires a large Allen key.
Old 08-11-2022 | 09:58 AM
470004's Avatar
470004
Congratulation on the new ride. Thanks for the information.
Old 08-11-2022 | 11:24 AM
HuntWhenever's Avatar
HuntWhenever
I wonder if the new dipsticks are compatible with older Softails? Might be a nice upgrade.
The following 2 users liked this post by HuntWhenever:
Glenn Gorman (08-14-2022), Uncle G. (08-11-2022)
Old 08-11-2022 | 01:46 PM
Uncle G.'s Avatar
Uncle G.
Not only that, you’ll probably save literally several grams of weight.
HuntWhenever (08-11-2022)
Old 08-11-2022 | 04:03 PM
HuntWhenever
Which will translate to 0.002 MPG. Every little bit helps!
Old 08-11-2022 | 08:06 PM
P51Driver's Avatar
P51Driver
Well I'm here to tell ya that the new trans dipstick makes checking the trans as easy as checking the engine oil.
Old 08-12-2022 | 08:14 PM
Kenelz's Avatar
Kenelz
I lay the wet end of the dip stick on a paper towel, it darkens the towel where its wet.
tideguyinal
08-01-2019 10:35 PM
Tarkus60
05-21-2016 12:59 PM
MNtadpole
05-05-2015 09:38 AM
BigGelvis
05-19-2012 07:34 PM
fogcity123
EVO
09-24-2008 09:38 PM
Quick Reply: Transmission dipstick change
