2018+ Softail Models Breakout
Jump start a 2022 (probably any 2018+) Fat Boy
Old 07-11-2022 | 08:18 PM
iHodor's Avatar
iHodor
Is there some reason the battery tender pigtail cannot be used?
Old 07-11-2022 | 08:23 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
Amperage. The pigtail wires are too narrow and it overheated and fries them.
You can trickle charge through it because its low amperage, but starters use massive surges of power.
The following 2 users liked this post by FranBunnyFFXII:
iHodor (07-11-2022), willcasp (07-13-2022)
Old 07-11-2022 | 08:52 PM
iHodor's Avatar
iHodor
Thanks Fran, I didn't think of that. I have a Noco and the leads are about 14ga so what you're saying makes sense. I'm pretty sure extra sets of cables are available for the nocos. For someone taking long trips it might be worthwhile to wire up a set much like the tender is. Though I haven't looked to see how much room is available at the posts. All I've heard and read is that the batteries are a pain to get to. Or at least it's not a quick or simple process.
Old 07-13-2022 | 12:57 AM
YHNYDad's Avatar
YHNYDad
I bought the noco cable (GBC007) and installed it so that if ever needed it is easy to jump. Didn’t want to have to get to the battery terminals as it is hard to get to with the additional aftermarket devices/wiring harnesses I have installed on my bike.
FYI I have the Noco Boost Plus GB40.
Just make sure the cable will work with the one you have.
GBC007: https://a.co/d/fKZJOJ0
I installed it and ran it so that it is right next to the battery tender cable. I didn’t want to have to remove anything to get to it. I tucked it in a little better than you see in the picture…though having it visible doesn’t really bother me…but that’s just me.
iHodor (07-13-2022)
Old 07-13-2022 | 08:51 AM
iHodor's Avatar
iHodor
You're set up perfectly!
Thanks for the link.
YHNYDad (07-16-2022)
Gibler77
12-06-2021 09:06 AM
Gommee
01-01-2015 07:59 PM
MrVertex
05-29-2010 06:57 AM
Quick Reply: Jump start a 2022 (probably any 2018+) Fat Boy
