Everything Low Rider ST Thread
#661
Ya, there is not much to it. A lot of 2-1 are like this, but I'm just happy I get the stock mufflers out of the way for good. Sucks you have to take them off for so much.
#662
The difference in power over stock is noticeable, and there is a huge weight reduction loosing one muffler, heat shields and the heavy factory bracket. And your right hamstring will love the heat reduction at the same time.
So thats 3 additional pluses that you can put in the plus column.
Powermankw (08-30-2024)
#663
Phil McGrath (08-30-2024)
#664
My FXLRST is about a year old. I had the first 1K mile service at the dealership (negotiated that into the deal). About a year out now and I was getting ready to change the oil, at 3350 miles, and the oil was not even registering on the dipstick. I drained about 3.5 quarts and it took a full 5 quarts to fill to the middle mark on the nominal fill area. Could be a combination of dealer not filling to an appropriate level - no idea why I did not check in retrospect - and burning oil. Just wondering if any others had experiences similar. There is no perceptible change in performance, it rides really well.
#665
Mine was half a quart high when I got it new. I had to take my bike in for warantee, and they said it was low. It wasn't, because I checked it the night before. I gave them mu oil, they put it in... Half a quart... And I checked it when I got it back... It's a half a quart high. Hot and Cold. So I don't know what the deal it.
New, my bike used pretty much no oil. I'm changing it today for 10K service, and it still does not consume any oil...hardly. Half a quart between changes maybe.
Are you checking it hot?
#666
Durham man (08-30-2024)
#667
#668
checking both hot and cold - on the jiffy stand - per the shop manual (which is same as the owner's manual) so I think that is correct. I did also measure it with the bike upright and it reads higher that way, but I have kept to measuring it on the jiffy stand to determine if the level is OK or needs more.
#669
I
