2018+ Softail Models Breakout
Everything Low Rider ST Thread
Old 10-26-2023, 03:48 PM
morooster's Avatar
morooster
morooster is offline
Originally Posted by NZLowrider
I have the Thrashing low bend bar along with their 9.5 inch pullback risers.it fit's me well and comfortable, (I am 6ft)- approx 3 inches higher and 2 inches further back than oem ones
Low bend is 22 degrees - do you find yourself hunching forward
maybe my arms are short or its my frozen shoulders
  #452
Old 10-26-2023, 03:53 PM
NZLowrider's Avatar
NZLowrider
NZLowrider is offline
It's not too bad further back than stock ones anyway, yes it does depend on your arm length
  #453
Old 10-27-2023, 08:37 PM
relayer4u's Avatar
relayer4u
relayer4u is offline
Tour-Pak:
The following 6 users liked this post by relayer4u:
Big Al 59 (10-28-2023), Calif Fat Bob (10-30-2023), CryingJoker (10-27-2023), JakeC7R (11-04-2023), morooster (11-02-2023), Piloto (12-12-2023) and 1 others liked this post. (Show less...)
  #454
Old 10-30-2023, 12:07 PM
Calif Fat Bob's Avatar
Calif Fat Bob
Calif Fat Bob is offline
Received 1,845 Likes on 958 Posts
DAMN @relayer4u Every time I see a pic of the Sands White bikes with the stock bronze rims, I get color envy. If the Gunship Gray bikes didn't have the extra 3hp, I would trade for the Sands. Lol Nice exhaust you have there too. I have the same.
For those that have not seen the Sands in person, the pics on the web do NOT do it justice. Simply amazing in person!
The following 2 users liked this post by Calif Fat Bob:
JakeC7R (11-04-2023), relayer4u (10-30-2023)
  #455
Old 10-30-2023, 01:14 PM
Big Al 59's Avatar
Big Al 59
Big Al 59 is offline
is this a protect screen in front of the headlight ?
  #456
Old 10-30-2023, 06:13 PM
Cootey's Avatar
Cootey
Cootey is offline
Man that's hilarious! you're gonna have so many people thinking this is an ACTUAL THING hahaha!!! Nice Easter egg! We all know that the black ones got the balanced engines and high flow heads. (imagine how that post would go in 10 years' time....)
  #457
Old 10-30-2023, 08:03 PM
relayer4u's Avatar
relayer4u
Yes, made by Dominator in Holland. Pricey, but I couldn't resist.
Dominator ST headlight cover
Big Al 59 (10-31-2023)
  #458
Old 10-31-2023, 10:55 AM
Big Al 59's Avatar
Big Al 59
thanks for the answer, it's a very nice finish...
  #459
Old 11-04-2023, 07:59 AM
spartan03's Avatar
spartan03
spartan03 is offline
Originally Posted by Rocketman83
I just replaced the risers on my wife’s LRST and used Poly bushings. removed the “tungsten rod” from the handle bars for the heated grips. She said the vibrations are less / better than before (stock)
I started another thread on the heated grip install specifically, but wanted to see if you could share your experience with me. After connecting the 69201750 kit to the USB caddy, the connector to the heated grip does not mate up. Does this require cutting wires and splicing? If so, what is the color orientation of the wires to be spliced? Or am I way off base
  #460
Old 11-04-2023, 03:00 PM
Rocketman83's Avatar
Rocketman83
Rocketman83 is offline
Yes, you will see another connector in the kit that fits the harness. They also give you the loose terminals. Since I already had a set of crimpers I bought when doing new taillights, I cut off the larger connector and crimped on the new smaller terminal and slide them into the connector.
The directions are terrible and don’t tell you that you have more connectors in the kit than you will use. The power connectors on the harley’s are all the same style. The two wire square-ish. But apparently there is a large style and a smaller style.
Quick Reply: Everything Low Rider ST Thread
