2021 FXFBS Evolution Industries Clutch FITMENT issue
So I went with this clutch:
https://www.fuelmotousa.com/i-238991...gm-spring.html
FM says it fits my bike but so far, it doesn't - requires not narrow cover.
While the issue is being handled by the FM, I am here for some help as there's more to it.
1. Clutch lever is so hard to pull that the mechanic said I won't be able to use it in the traffic.
And as a "proof", that little red piece on the clutch wire broke off while pulling the clutch.
I went with this type (diaphragm spring) after reading this:
Am I missing something here?
Is it due to a heavy spring in the set?
2. Are coil spring type clutches narrower thus would fit under that narrow primary cover? I.e.:
https://www.fuelmotousa.com/i-238990...l-springs.html
The Evolution diaphragm clutch has better feel than the coil spring version. As a result, this clutch is perfect for a daily rider. Diaphragm Kits Include a Heavy Spring to accommodate Most Horsepower Applications.
Received 4,914 Likes
Skippy49
02-19-2008 02:22 PM
