2018+ Softail Models Breakout
How do my dyno runs look?
Old 11-11-2021, 08:49 PM
BuddyB's Avatar
BuddyB
BuddyB is offline
Originally Posted by RocketyMan
So I had that exhaust on my bike and I HATED it. On mine it had a terrible exhaust leak where the collector is denoted by the carbon trail where it slips over. Because of this design, there wasn't anything I could do to fix it on the pipe. I think the three-piece exhaust types aren't that great.
Do you notice any carbon build up on the collector on yours?
No I didn't notice any when I took it off at the time of the Cam swap. I haven't noticed any exhaust leak.
Old 11-11-2021, 09:04 PM
FXLRyan's Avatar
FXLRyan
FXLRyan is offline
Awesome cam of choice, the pipe is not the best but it still pulls decent numbers
Your bikes tune is holding you back, and that’s mostly due to your FP3. The fp3 isn’t good for anything past a pipe and air cleaner.. since your warranty is long gone I’d recommend buying a PV from fuel moto, they can pre load a tune onto it and I guarantee the AFR will be a lot better than what you have right now.
BuddyB (11-11-2021)
Old 11-12-2021, 01:08 AM
OrangeThunder's Avatar
OrangeThunder
OrangeThunder is offline
As others have said, the pipe is definitely hurting you below 4k. The rest looks great, congrats!
BuddyB (11-12-2021)
Old 11-12-2021, 11:28 AM
RocketyMan's Avatar
RocketyMan
RocketyMan is offline
I noticed mine on the backside where the two springs hold the collector on to the two individual head pipes. The heat shield on the front blocked this for me. But at any rate, max power for our Harleys runs at an AFR of around 12.4 ish for full throttle--somewhere in a range of 12.0 to 12.8. Your dyno of 4000 rpms up to about 5400 rpms shows the AFR leaning out a bit. Also on your torque dip getting too fat. Kinda all over the place--but that could be the dyno's WBO2 being wonky.
I bet if your AFR was corrected on the torque dip being too fat and the higher RPMs being too lean might gain some improvement there.
BuddyB (11-12-2021)
fordhd2005
Milwaukee Eight (M8)
14
02-16-2021 08:17 AM
patrikr
03-02-2013 01:08 PM
FBFletch
Exhaust System Topics
17
10-22-2011 06:45 AM
willie37
05-27-2009 11:03 AM
puma
01-03-2009 07:57 AM
Quick Reply: How do my dyno runs look?
