Belt tension and alignment question.
Hi guys
I have quick question. Lately I brought my bike to dealer for tire change. My bike 2019 Heritage experienced infamous belt squeak as many had experienced due to too tight belt. I asked dealer to adjust the alignment and belt tension. I got the bike test rode it to max speed and everything seems fine no wooble, belt squeak etc. All seems to be good.
Today I purchased belt tensioner tool and I decided to check dealers job. Instead of adjusting belt so it would move 4.5 notches on belt tension window (which would indicate 9/16” slack which would be in specs and what I wanted) these dummies loose my belt to the degree that I can move it up to 9 notches (in the belt guard window) which would mean 18/16” since each groove width is 1/16” as per manual.
I am considering adjusting the belt but wouldn't want to mess with alignment so I thought I can make a dot on axle adjustment screw (one pushing axle in the swingarm) and turn it let say half turn on each side to increase tension till proper specs. I thought this way I could keep up alignment proper while still adjust my belt.
What do you guys think? Will this method work?
Side question. Did you notice tension of your belt to increase after you ride it for a while or under heavy load with passant and filled up bags etc? If yes how much tighter it is?
Bike rides fine but from my research looks like it might cause belt to skip teeth if too loose and damage belt which would be a shame.
Since thread on adjustment screws is evenly spaced I thought same thing that if I will mark it and control how many turns I do on both sides this should work.
Hope others will chime in as well to assure me this logic is valid as I dont want to mess something up.
I actually checked graduation marks and these were spot on 1/16” each and yes this belt has double slack of max amount recommended so I think I will have to do something about it 😢.
natural gasser (11-11-2021)
Thank you guys let me provide some additional info here. I used belt tensioner tool and check belt while bike is on kickstand, cold, no weight on the bike as per manual so I think I am doing this part correctly. As I measured it I am at 14/16 loose for now.
Here are factors that made me question if I should adjust this belt to tighter spec:
1. As said by one of the posters if adjusted to factory specs there is this squeak which is obvious sign of belt that is too tight.
2. based on what I researched on our forum after bike warms up this tension might increase up to 1/4” which if is true would put me in the 10/14” during this conditions so I would be tad over specs
3. looks like Hulkass also mention specs vary depending on if the bike is on kickstand or vertically which again tight the belt (btw would like to get link to this post if anyone has it)
4. additional load could potentially affect tension by about 1/8” from what I have seen proven to be true on one of YouTube experiments
So if I combine all these factors I wonder what to do? Feels lika adjustment would be the right thing but I am afraid this squeak will be back this way and I will end up being too tight during normal operating conditions 🤯
At least you guys confirmed my idea of marking adjustment bolts and counting turns during adjustment should work so I can keep my alignment in check so this is good news.
Please let me know what you think?
