Upper Clutch Cable Length - 10" Ape Hangers
Hi,
I am planning to replace stock handlebars(Dragbars) on breakout 2018 model with 10" Ape Hangers ( Carlini Evil Ape 10” Non Stepped Black Throttle By Wire ) using low riser 1" 1/2 . Can anyone advise on the length to go for upper clutch cable ? Thanks
Unless someone comes along and has done the Carlini bars on a Breakout, the best thing you can do is mock up the bars and take a measurement. Then, order the clutch cable.
I did look up which cable your bike would take on a set of 10.1" rise Fused Lo Handlebars. For those bars, according to the H-D Handlebar Installation Requirements manual, you would use 37200327 (41") upper clutch cable.
Good luck!
Good luck!
Thanks
Good luck!
Good luck!
Funny you asked, as i am doing the research on brake line this very moment. Have you got any ideas !! I've noticed in US you can buy the whole cable kits (Burly, la choppers etc) but most of them for 12-14" bars and not 10". Do you reckon it's best to get the whole cable kit that will inlcude harness as well. Than again i am not sure if the kit will include just the upper clutch cable or the full length clutch cable.
The following 2 users liked this post by Sinthroid:
2019Breakout114 (09-04-2021),
Joe Black (08-06-2021)
Thanks
That's looks great, mine's the same bike. Think 10" apes i bought are bit shorter with low risers, so decided not to install it yet. So looking for 14" apes that might suit breakout profile, was looking at 14" from Burleigh Bars, they are 2" fat, not sure yet if they'll look good or be over killed.
Yeah, part #37200216 is the OEM upper cable for the Fat Boy, Street Bob and Softail Standard.
