Oberon Levers
Oberon Levers
I installed a set of Avon grips and a set of adjustable Oberon clutch and brake levers this weekend.
I bought medium grips and with gloves on they were not as comfortable as I liked. Unfortunately I threw the container away. I went ahead and ordered a set of small and they are perfect.
These are the Memory Foam.
Then I installed a set of Oberon levers. My fingers always grabbed the lever by the tip of the finger and when I let the clutch out I tend to hold onto the lever. A few times I let the lever out
and give it gas and it doesn't move. Then I realize the release of the clutch is that last half inch.
Happened to see a Harley in the showroom with Oberon Levers and sat and played with them for a few minutes. Went straight to the parts counter and ordered a pair. They have 8 positions.
I am experimenting with 3 and 4 right now. Probably settle on three.
It is amazing how much a little change like the diameter of the grips and how far you have to reach for the lever makes. I lowered the bike and put the Harley Pull Back Risers on and they
were not large adjustments but help the comfort tremendously. I know all this depends on your size and height.
I'll attach 2 pictures of the levers. The right side shows the adjustment **** more clearly. In the pictures it makes it look like the fron of a portion of the levers are silver but that is a glare from
the Fluorescent lights in the garage.
Althea (07-23-2021)
OldMike, the instructions state that on some models you may not be able to start in gear at number 3 or lower. That is what mine does.
That part doesn't bother me but after some of the comments I will watch for the bleed down. Does it actually loose any fluid or just drop to the point you have to pump the lever to bring it
back to normal? I am asking because so far I have not had that problem.
I was in the market for adjustable levers, I contacted Oberon to ask about the issues, and if they had done anything to solve them, after several attempts I never got a response, so I ordered Rick´s levers instead. I am very happy with them, I am able to start the bike in gear on all clutch lever positions and 0 issues on the brake lever
