2018+ Softail Models Breakout
Need to know how to gain access to the steering head bearing on my 2020 Lowrider S
Old 06-14-2021, 05:14 PM
Profes's Avatar
Profes
Profes is offline
Stage II
Question Need to know how to gain access to the steering head bearing on my 2020 Lowrider S
I have a lot of wobble going around 50-70 mph and I need to mess with the bearing just don't know how to get in there to do so. I want to try doing it my self before I take it to the dealership.
Old 06-23-2021, 02:56 PM
FattyMcJ's Avatar
FattyMcJ
FattyMcJ is offline
You're looking for #1 & #2. This is from the service manual & doesn't quite look like ours, but you get the idea.
Profes (06-29-2021)
Old 06-23-2021, 03:04 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,719 Likes on 2,000 Posts
Don’t forget to loosen the lower (or upper) pinch bolts before attempting to adjust the head bearings.
Old 06-28-2021, 08:08 PM
Since 1968's Avatar
Since 1968
Since 1968 is offline
It's possible that the steering stem will have to be loosened slightly when intuition tells you to tighten it. When they bearings have too much pre-load they tend to 'stick' ever so slightly and the bike seems to wander as you make tiny corrections. In other words, the bike won't self-center the way it should.
If you're really going to get into this, you might want to invest in a shop manual. It's great to see another guy jumping in to the world of DIY!
The following 2 users liked this post by Since 1968:
Las Vegas Jim (07-05-2022), Profes (06-29-2021)
Old 06-28-2021, 08:18 PM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,809 Likes on 11,294 Posts
Check your tires, and wheel bearings. Those are the most common contributors to wobble.
Old 06-29-2021, 10:32 AM
RocketyMan's Avatar
RocketyMan
RocketyMan is offline
So I take it there is no zerk fitting to grease the bearings in the tripple tree?
Old 06-29-2021, 10:49 AM
twincam10353's Avatar
twincam10353
twincam10353 is offline
Even if there was, that would only dump grease into the neck (completely useless). It wouldn't grease the bearing.
Dan89FLSTC (07-06-2021)
Old 06-29-2021, 01:29 PM
RocketyMan's Avatar
RocketyMan
Previous generation softails had a zerk fitting there and you would pump grease in it enough that grease would flow out of the upper and lower bearings.
Old 06-29-2021, 03:43 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
One of the reasons I dislike the new Softails. A job which used to take me five minutes (including wiping up the excess grease) now takes more than a day to accomplish (assuming it will ever be done at all).
I suspect I’ll just run the head bearings to failure since the labor to grease them is the same as the labor to replace them.
Just one more example of the disposable society we’ve created.
Profes (06-29-2021)
Old 07-05-2021, 09:07 PM
Profes's Avatar
Profes
Profes is offline
Stage II
so I tried this but there is nothing to adjust.
do I have to remove my hole front end in this case ?
Quick Reply: Need to know how to gain access to the steering head bearing on my 2020 Lowrider S
