2018+ Softail Models Breakout
USB Caddy delete/Wire tuck
Old 10-10-2022 | 06:32 PM
Gripfxbbs's Avatar
Gripfxbbs
Originally Posted by snake_eyes
So, if it weren't for the USB port you WOULD be able to do the wire tuck without the tank lift?
yes you do not need a tank lift. You should be able to put the usb port anywhere it will reach. Or tuck it up in the frame if you dont need/use it.
snake_eyes (10-11-2022)
Old 10-22-2022 | 11:40 PM
rideamap's Avatar
rideamap
I ended up removing the tank lift and yes, you can still do the wire tuck and here’s where I put the USB. It does not interfere with steering.
snake_eyes (10-23-2022)
Old 11-10-2022 | 12:37 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
OOH so the horn isnt attached to the plastic caddy itself, it attached to the bracket, and then the bolts thread into the caddy. Ok that makes sense.
I'm gonna remove that thing I dont even use it.
rideamap (11-28-2022)
Old 11-27-2022 | 07:01 AM
BRTJ's Avatar
BRTJ
Put me in the camp of "this wasn't a problem until this thread but now it must go" lol. Good work OP
Old 11-28-2022 | 07:47 AM
MoneyFor's Avatar
MoneyFor
That plastic box doesn't bother me at all, I even used it to incorporate an SAE socket. This can serve as a 12V source or, as I intended, to connect the trickle charger. Will do this on all my M8 models soon.....
Old 11-28-2022 | 11:57 AM
Tha_Big_Ohh's Avatar
Tha_Big_Ohh
why not use the charging plug that come pre installed on the bike?
Old 11-28-2022 | 11:56 PM
MoneyFor's Avatar
MoneyFor
Because I didn't like the location of it , at the bottom of the battery cover lying down on the engine block.
13RoadKing
Electrical/Lighting/Alarm
02-28-2017 07:17 PM
PPBART
11-01-2012 08:03 AM
Traces72
08-11-2012 04:59 AM
RonRock
05-14-2010 09:37 AM
jed1069
10-17-2009 08:46 AM
Quick Reply: USB Caddy delete/Wire tuck
