2018+ Softail Models Breakout
Adding ABS FXBB Help
Old 02-25-2021 | 01:24 PM
miT's Avatar
miT
Default Adding ABS FXBB Help
Hey All. New to the HD world and new to this forum. I picked up a 2020 FXBB and made a list performance upgrades I desire. One of the check boxes is adding ABS. I have successfully done this on other model bikes and was wondering if this is possible with HD's?
The mechanical portion of this process is easy (its just parts, wrenchin`, and a some harness changes). What I am having a hard time finding an answer on is the ECM configuration. Can ABS be configured with digital Tech II (On / Off)?
Old 02-25-2021 | 01:57 PM
rigidthumper's Avatar
rigidthumper
Veteran: ArmyVeteran: Navy
No- ABS has separate HCU and ECU, and is not plausible below the MFR level.
Las Vegas Jim (02-28-2021)
Old 02-26-2021 | 06:39 AM
MoneyFor's Avatar
MoneyFor
I would rather sell the bike and buy one with ABS on it then going thru all that hassle if you really want that.
FattyMcJ (02-26-2021)
Old 02-26-2021 | 11:58 PM
miT's Avatar
miT
Not what I asked, but thanks!
Old 02-27-2021 | 12:28 AM
miT's Avatar
miT
After studying the electrical schematics and reading how the ABS functions on this bike, it appears the EHCU operates independent of the ECM. The only communication between the two computers is a VIN check. I assume this is to ensure the ABS / EHCU uses the correct calibration tables associated with the year/model bike.
Outside of using Dig Tech II to program the EHCU to the bike for recognizing the VIN, adding ABS appears to be all mechanical. I've got a donor bike coming soon, this will be a good experiment.
Old 02-27-2021 | 12:42 AM
MoneyFor's Avatar
MoneyFor
Good project if you continue with it, am curious about the result, keep us informed about the progress.
Old 02-27-2021 | 06:46 AM
rigidthumper
DT2 does not have an "ABS" enable/disable function. That is a factory setting- do you have access to the factory ECM controls?
miT
02-25-2021 01:22 PM
cj24
34
05-19-2019 05:48 PM
wavesnwheels
04-21-2015 03:54 AM
1HDRIO
Harley Davidson Videos
08-07-2014 08:28 AM
dt20
03-06-2008 01:06 PM
Quick Reply: Adding ABS FXBB Help
