CVO Tank Emblems
The following 5 users liked this post by Bob Z.:
07UltraGuy (07-05-2023),
Bulee (11-17-2022),
Crispy (10-14-2021),
Felix 808 (08-09-2023),
HarleyDEU (10-17-2021)
Friend had a set and he used a rubber curved pad that they use to attach sandpaper to when doing body work for bending the badge...heated the badge with a heat gun paying attention to not get it too hot and then pushing it against the rubber pad to get the curve...He had matt paint so used the rubber pad as he didnt want to get the matt paint screwed up from the heat..Careful as once the badge gets too hot it will melt and twist...May work for you ..Good Luck
The following 2 users liked this post by Crispy:
talkingrock (07-05-2023)
