S&S 465G cam upgrade issues
Hi Guys,
my bike is Breakout 107 with Blow performance exhaust,mini tear drop filter from S&S and FP3 tuner.
I have install 465 cam with gear drive/new tappets /stock pushrods and here is mi issue run on autotune for nearly 3 fuel tanks and engine is great lots of torque and power
but when is under load its fine as soon i let go of throttle and bike slow down its beginning snatching,need to work with clutch a lot and constantly changing gears
i dint experience anything like that before ...any ideas?
Johnny C (05-22-2022)
I think that's a great looking exhaust. If you like the sound and are going to keep it you will need a more capable tuner. I would find a shop that knows how to tune with TTS Mastertune. Call TTS for a recommendation.
You should be OK with the S&S 465 cam, however, you may need a cam with less valve overlap if it refuses to tune well. That short open exhaust is a challenge to tune.
I believe his use of "snatching" is what we would probably refer to as "bucking" during low RPM deceleration. Very common with longer duration cams, and exacerbated by manual transmissions, only 2 cylinders, and a relatively light flywheel effect.
I'd be surprised if it can be tuned out completely.
Hi Guys,
Hi Guys,
#metoo
Hi Guys,
