FXRT fairing on a 2020 low rider s?
#31
I am very happy with my v2h fairing. Edit, I see you are asking about the fxrt fairing, disregard.
#34
The following 2 users liked this post by shiftace:
Highwaymans (04-01-2022),
natural gasser (03-29-2022)
#36
Planning on touring this summer, so the FXDXT fairing would not be going back on untill after the tour.
Mocked-up, ready for paint.
FXRT fairing, lowers, and pods are from JD Customs. Headlight bezel is TOL Design.
The pods have BaJa Designs’ Squadon-R Pro and the headlight will get the LP6 Pro.
The following 4 users liked this post by 2waam:
druski (04-20-2022),
HuntWhenever (04-21-2022),
natural gasser (04-21-2022),
PistolPeteSTL (04-28-2022)
#37
#39
I order the TOL Design bezel because I am running Baja Designs’ LP6 for headlight. LP6 generates too much heat, needs airflow.
No trimming needed on the fairing. However, few holes need to be drilled where the cross-member mount and the lower bracket (fairing & lowers).
The lower bracket mounts on the frame. There should be a bolt hole behind the master cylinder and a corresponding bolt hole on the left-side.
#40
