The fairing of my Sport Glide rattles when I ride over uneven terrain. I’m pretty sure it is seated correctly. Can’t figure out which spot creates the problem, so I cannot fix it. Has anyone encountered and identified it? Thanks!
Not sure on the sport glide....on the heritage with the removable windshield i keep the bolts snug on the quick detachable hardware.
Not really quick detach because i have to loosen the bolts first.
If it rattles on a ruff road something is loose. Keep tightening you will find it.
There are 7 bolts that hold the fairing together and 2 bolts for the windscreen. Maybe a loose or missing bolt? A missing bolt would have the clip nut rattling inside.
On a Sport Glide it is also possible the fairing is bouncing at the point where it rests on the lower tree. I put thick black tape at that point and it stopped the rattle and the rub mark.
Dumb question time - Are you certain its the fairing?
Not a dumb question! I’m dumb for assuming it was the fairing. Rode without it today and the rattle is still there. Doesn’t seem to be the gas cap either; I rode while holding it down and the noise was still there. The search continues......
