2018+ Softail Models Breakout
FXBB wheel fitment help
Old 06-10-2020 | 08:57 AM
Jonwayne14's Avatar
Jonwayne14
Default FXBB wheel fitment help
Hey I’ve been trying to get mag wheels for my fxbb. I’m buying a set of 13 spoke from a 19 sporty I’ve seen people make the conversions just wondering if anyone has tips or tricks to help. I found a spacer kit for the swap at tmf cycles but he’s had a few people tell him the rear caliper and disc don’t line up properly and some people never make complaints. Any information would be great especially about the fact the the rear wheel is gonna have to be flipped directionally
Old 06-12-2020 | 06:23 AM
Yjoe_3's Avatar
Yjoe_3
6th Gear
I put sporster 9 spokes from a 2019 on my 18 fxbb and it took a little bit of engineering to get done. I bought my spacer from tracker/die. The front fit easy but the rear need spacers cut for the drive side. I also installed a chain kit during the process. Just be prepared to spend extra trying to find right spacers and for the sprocket also.
Old 06-12-2020 | 07:34 AM
Jonwayne14's Avatar
Jonwayne14
so ironically I thought I was getting 13 spoke but these r 9 spoke off a 19 sporty also below is the link to the conversion kit I found. The guy said the kit fits the fronts perfect but some people had problems with the disc and caliper alignment in the rear did you run into tht? Also would all the spacers you got work with the belt configuration? If so any chance you know What the size of spacers I need or maybe I could find a way to get the same order you put in wth that guy?
Old 06-12-2020 | 08:38 AM
Yjoe_3's Avatar
Yjoe_3
6th Gear
I did not have a problem with the rear rotor or cailper, I believe i used the stock spacers on that side. The put 2 spacers together for the drive side and i dont remember the length. As for the belt sprocket im not sure because i switched to chain and that was pain to space that out also.
sorry if none of this helps. You will have to mock everything up and measure. But that kit from tmf cycles should be close
Old 06-12-2020 | 10:57 AM
Jonwayne14's Avatar
Jonwayne14
i figured between that kit and the stock spacers I could make it work. You use your fxbb axle too? With or without a sleeve
Old 06-12-2020 | 11:55 AM
Yjoe_3's Avatar
Yjoe_3
6th Gear
My wheels had bearings and sleeves. Axles slide right through
Old 06-12-2020 | 01:01 PM
Jonwayne14's Avatar
Jonwayne14
Almost positive these ones do too. Thanks for the info man if I run into any problems I’ll come back here for help lol
Old 03-25-2021 | 01:13 PM
Jonwayne14's Avatar
Jonwayne14
hey man if your still on the forums I’m getting ready to do this swap was wondering if I could pick your brain a bit. Thanks
Old 01-05-2022 | 02:52 AM
BobbedOutFXBB2020's Avatar
BobbedOutFXBB2020
Default 2020 fxbb with 2020 low rider mags
****ing ****
The following 2 users liked this post by BobbedOutFXBB2020:
FenderBndr (01-13-2022), KaiserGB (01-10-2022)
Old 02-22-2022 | 06:39 AM
Malcvtr's Avatar
Malcvtr
6th Gear
Originally Posted by BobbedOutFXBB2020
****ing ****
Hi. Did you need spacers or any other adjustments to make these fit? Thanks.
Quick Reply: FXBB wheel fitment help
