FXBB wheel fitment help
You just need spacers for the front wheel. I bought the LA chopper Axel Spacer Bar 25mm. With the tube i took it to a shop and they took measurements and they cut a spacer for the left and right side of the wheel. The rear tire is plug and play. When you buy the MAGs from HD they don't come with a crush tube, valve stem, wheel bearings etc. So you will have to get all those parts for a "street bob" not the low rider.
BobbedOutFXBB2020 (02-25-2022)
the rear fender is a low rider s fender. I only added the low rider s fender so I can run a 180 tire in the rear. Also i have the RWD mono shock which is creating the fender gap. The low rider Mags have no problem fitting a 150 or a 160 tire with the FXBB fender. I just wanted a more beefy tire.
streetmaster56 (02-25-2022)
h2otoad
08-12-2021 01:13 PM
