Easy 19" front wheel for FXFBS
#43
johnnyhumble (08-30-2020)
#44
I emailed the dealer in the picture about that bike and here's what they told me about that back wheel......
"The bike you saw was accessorised in our shop here a couple years back. We fitted the stock Talon wheels off of a 2018 FLHRXS Road King Special. The front was an easy install, but the rear had to be flipped and each side machined and tapped to fit properly (pulley went onto disc side of wheel, disc onto pulley side, wheel in backwards rotation)."
#45
#47
I just by chance picked up a brand new 2020 Road Glide complete Prodigy wheel (rotors, bearings and tire).... I may try it out on the new fat bob and see if I like it.
Does anyone have the torque specs of the axle and pinch bolts? (I'm still waiting on my service manual)
thanks
thanks
#48
Have you tried to bolt this wheel on? It looks like the rotors mount the same as the enforcer wheel. There is another guy that put the enforcer front wheel on and is not running a front fender because the rotor bolts contacted the fender mount.
#49
The rotor bolts are the domed headed ones, so to run a fender someone would need to replace them with the flat head style bolts or just notch the fender mount with a dremel. I think I took a pic of it and will try to post it so you can see the clearance.
24v (08-30-2020)
#50
Yeah I put it on and rode around the block a couple times without the fender.
