Easy 19" front wheel for FXFBS
#31
Finally got my 19" Turbine front wheel but no rotors so time to hunt !
My question now is does anyone know what options I have in terms of rotors ? Definitely want to upgrade but I'm not sure if I have a wide range of options because the HD turbine rotor description states: "Fits ’14-later XL ’06-17 DynaŽ (except FXDLS) ’15-later SoftailŽ (except FXSE) ’08-later Touring and ’09-later Trike models with Original Equipment or accessory wheel with 3.25 bolt circle rotor mount." so I wonder if that can be reversed allowing specific XL/Dyna/etc rotors to work but if so, is there a diameter limit ? (12.5" vs 13")
#33
Search for part # 58900473dh
#35
#36
I had the shock extension plus taller tires and felt that helped increase the lean angle. Now that I have a touring bike and sometimes ride back roads with the same group I realized it's partially the rider. Some guys don't know how to take a good line on curves.
#37
I hear u . You had that fat bob hooked up! The one I test drove was a blast, can only imagine with the extra lean angle. I might do something like that with my lrs in the future.
#39
Gintonious (07-28-2020)
#40
